주요 콘텐츠로 건너뛰기
Apple은 MacBook Air 13"를 2017년 6월에 새로운 Broadwell Intel Core i5 프로세서로 업데이트하여 성능과 배터리 수명을 약간 향상시켰습니다.
423 질문 전체 보기
Topcase exchange US -> EUROPEAN
Hi everybody.
Can anybody tell me how to sync a A1466 logicboard with the Topcase. Changed the topcase from US layout to european Topcase, but left Shift Key is not working.
Already tried several steps (Internet recovery, SSD from european version with OSX pre installed) but nothing solved the issue. :-/
I'm not able to change the layout from US (10 Keys between left and right shift key) to european layout (11 Keys between left and right shift key)
Thanks in advance,
Ben
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
@littlebigb - Did you also switch-out the trackpad or did you reuse the one from the original uppercase?
Hi Dan,
Yes, I reuse the one from the original uppercas.
댓글 달기
답변 1개
선택된 답변
If you have performed all software tweaks found in system preferences/keyboard to no avail try resetting SMC: turn off the Mac, press shift+ctrl+alt+power..you'll see magsafe light going from amber to green and amber again. Boot the Mac and before the chime press alt+cmd+P+R and keep them pressed until the second chime to reset Pram. If no joy, try reseating the keyboard cable on the logic board.
If none of these work, possibly you got a faulty topcase.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
+1 vote for faulty topcase if SMC reset does not help.. though I feel I might be missing something..
Thanks. I'll try it tonight. :-)
댓글 달기
귀하의 답변을 추가하세요
Little Big B 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 102
