주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
Battery connector dislodged, pins apparently left unharmed
Took me ages to get this thing to snap open, and now it looks like I ruined the battery connector while trying to release the brown thing keeping the cable in place. Just after I had finally managed to get around that cursed metal casing... I tried putting the socket back and it seemed ok, but nothing happened when I reattached the battery flex cable. Is this something I could realistically fix at home? I’ve read nasty stories on ifixit involving soldering the PCB (or just replacing it altogether) and I really wish there was a simpler way to put it back on track. I don’t see any pins stuck inside the plastic part btw. Thanks! https://imgur.com/a/RhRDDU7
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
try putting the battery connector back on with respect to the appropriate position if u can’t turn the device on
you can get battery connector here http://s.click.aliexpress.com/e/bJSBFSxA and make a professional do the soldering for you cause i messed up two ipods the same way thinking way over confident of my solder skills.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Antônio 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 50
