주요 콘텐츠로 건너뛰기
우리가 수리 방법을 안다면 우리가 고칠 수 있는 많은 것들이 있습니다. 이 곳은 특정 수리에 필요한 가장 전문화된 기술 목록 작성을 목표로 하고있습니다.
489 질문 전체 보기
What exactly is binary code?
What is binary code? i keep hearing about it but never really understood it.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
선택된 답변
Binary code is the most basic form of data composed of 0's and 1's. A "0" or "1" is called a bit, and eight bits are called a byte, then 1024 bytes make a kilo byte and so on. The 0's and 1's are based off probability. This is the reason why 0 means False and 1 Means true.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Absolutely, your explanation captures the essence of binary code succinctly. In this digital language, the binary system's elegance lies in its simplicity, with bits forming the building blocks of information. The hierarchical structure from bits to bytes and beyond showcases the scalability of this system. The concept of 0 representing False and 1 denoting True reflects the binary logic inherent in computing, where electronic signals interpret these states to execute commands. It's a testament to the foundational principles that govern the intricate dance of data in the digital realm.
댓글 달기
This is a very generic simplified explanation. In it's essence it is a numerical system based on 2 (0,1), unlike the numerical system we are accustomed to which is based on 10 (0,1,2,3,4,5,6,7,8,9). However the best way to think about it is on and off. On is 1. 0 is off. Digital circuitry only understands 2 states on and off. So binary code is how you talk to ICs on their level. All computer programs, usually through an interpreter are converted to binary code otherwise your processor, memory etc.. would not understand what was given to it or what to do with it.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Binary code is the fundamental language of computers, expressing data using only two digits: 0 and 1. In essence, it's a series of switches—0 representing "off" and 1 representing "on." This binary system underpins all digital communication and computation, serving as the backbone for everything from basic arithmetic operations to complex software algorithms. It's the digital canvas upon which the intricate tapestry of modern technology is woven, translating our instructions and data into a language that machines can understand and execute.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Derrick 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 1,170
