주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
Why does an iPhone 7 not turn on with charging port plugged in
Hello, I had an iPhone 7 come in DOA. No signs of life, cracked screen, wouldn't take a charge. After opening the phone, it has no signs of water damage or anything visibly broken. I went through steps of diagnosing the issue. Started with new screen (no fix). Then connected a different battery, nothing. Then decided to replace the charging port. At this point the phone came on, but went into a boot loop. So I disconnected the charging port and reconnected the second battery, and the phone came right on with the original cracked screen. The replacement charging port is an OEM charging port. I am assuming the original battery that is still connected is just very dead as it obviously wouldn't take a charge from the original charging port. Any ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
What happens when you plug the charging flex then plug a charging cable while the phone has successfully booted and is on the lock / home screen?
If the phone doesn't show charging response then it's definitely the Tristar chip.
If apple logo does not appear on either charging ports while battery is unplugged but charging cable plugged in it's the tristar as well.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Will the second battery take a charge after it dies? I have seen the tristar chip go out or start to fail, which causes this.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
matt mocciola 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 111
