주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz) 또는 2.5 (Turbo Boost 최대 3.7GHz) GHz 쿼드-코어 Intel Core i7 프로세서.
Not starting after battery replacement
Hi, I followed this link - - - > MacBook Pro 15" Retina Display Mid 2014 배터리 교체
I have all the tools and an anti static mat but after going through this 3 times my Mac will not boot. I get an amber light on the Magsafe charger, if I SMC reset the light goes to green but the Mac simply will not start. No fans no display , nothing.
Any ideas please?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 5개:
Can you post some high res pictures of the area around the battery connector and the area around the PCH (The Large Chip to the left of the battery connector. Ive had quite a few of these come in my shop with resistors knocked off right under the PCH after having a battery replacement done, causing it not to power on.
Hi, thanks this is done.
Can you disconnect the battery and try to start your laptop from charger only with battery disconnected? You want to rule out a bad battery.
Hi, thank you. I tried this and it still does not start.
@bob_reno Hi what was solution please? My issue is same after battery replacement... Thx
댓글 달기
답변 1개
  1. Remove both the battery and the charger
  2. Press and hold the power button for 10 seconds
  3. Re-connect the charger while holding the power button, keep holding the power button for 10 more seconds
  4. Re-connect the battery, try powering up your computer if it has not done so itself already.
This worked for my friend when he got no power after a battery replacement on his MBP. Hopefully this works for you too.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Can you start a MacBook if you just disconnect the battery from the motherboard with its connector and leave the back cover off ? I changed the battery for a new one and all I get is a MagSafe with orange light and the Mac won’t start up at all. Tried sec reset and all key combinations to start up … no effect … if I can get some help it would be great !
댓글 달기
답변을 추가하세요
Bob Murray 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 12
전체 시간: 481
