주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Can an iPhone charger kill a battery?
Hey guys,
So I heard this story from a customer. He bought a charger for his iPhone 5s and plugged it in, first it charged, later it stopped and the phone wouldn't charge anymore. Later, the battery died and he bought another charger, but nothing happened when he plugged it in.
So I looked like a few days ago and the charging port works fine when I connect the old battery, but when I connect the new one, it doesn't charge and it doesn't turn on.
Now I don't want to be a jerk and say, it's your fault because it's probably a really bad charger.
So my question is, is it possible that the charger killed the entire battery.
By the way, the battery was new and fresh from iFixit.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The charger the customer used blew the Tristar chip on the phone's logic board which is used to control the power coming from the charging port to the battery.
Some symptoms of a bad Tristar:
- Phone not charging while phone is turned on, even with a new charging port.
- Phone not charging flat batteries (This is one of the most common ones)
- Fake charging (No power draw from charger but phone says it's charging. Tested with USB Ammeter)
- Apple logo not going on by itself with the battery unplugged but charging cable plugged in.
You'll need to get the Tristar chip replaced by someone that does board-level repairs / microsoldering for iPhones. Also tell the customer to throw the charger that he used in the bin as it ended up damaging the phone, the charging cable too as it's probably a non-MFI certified one / cheap aftermarket cable.
Original or MFI-certified (basically most of the reputable brand) charging cables have a chip embedded (right near the lightning connector) in them for surge-protection to avoid stuff like this happening from cheap wall chargers / car chargers.
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
Thanks. Well I hope it's something else, because it's not my fault it seems, because I always use original Apple chargers and cables that came with my iPhone.
Hey Ben, so I just replaced the battery and it's been charging for like 10 minutes now and it's still stuck at 20%. I think you're right. So I guess I should let the customer pay for the Tristar repair?
With my customers I don't charge them until the phone gets fixed.
I have a no fix no fee model.
댓글 달기
귀하의 답변을 추가하세요
Stijn Helmonds 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 1,046
