주요 콘텐츠로 건너뛰기
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 질문 전체 보기
질문 마감됨
What are the different inertial sensor in the iPad 2 3G?
Good morning everyone,
I am currently working on an algorithm that uses iPad 2 inertial sensors. I learn a lot reading the iPad 2 teardown made by iFixit.
Yet I still have some questions :
>> The iPhone 4 have 3 accelerometers, 3 gyrometers and 3 accelerometers. What about the iPad 2 3G?
>> I understand that the iPad 2 has ST Microelectronics MEMS and I found the accelerometers thanks to the reference given in the teardown (LIS331DLH). Yet it is impossible to find the gyrometer using the reference AGD8 210. Any ideas why?
>> Finally, what about the magnetic sensor (compass)? Does the iPad has ones? Is it a three axis compass or only a one axis? What is the reference of this MEMS?
Thanks a lot for your help. I need these informations in order to develop an inertial filter and I need to know what informations I will be able to use.
Have a good day.
Laurent
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Hi Laurent,
I'm very interested with programming a navigation algorithm using Kalman filter with all available sensors. Apparantly iPad 2 has 3-axis accelerometers, 3-axis gyroscopes and GPS (3G version).
I'm currently using Asus Eee Pad, pretty cool, it has quite some apps that can extract sensors data, GPS, 3-axis accelerometers, 3-axis gyroscope, 3-axis magnetometers ...
KL.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi Kyle,
Thank you for your response.
I am still working on the same problematic but since my question, we bought an iPad2 and started working on it. It appears that the iPad 2 has 3-axis sensors of all kind : 3-axis accelerometers, 3-axis gyros and 3-axis magnetometers (or compass) wich is perfect for the implementation of a Kalman filter for attitude estimation.
Apps like "sensor monitor" on iPad/iPhone allows to catch in real-time all these datas (and also GSP) meaning that iOS SDK allows a direct access to original datas. The developper then has to implement his algorithm, like a Kalman filter.
I started to develop on the iPad thanks to softwares like Unity or Airplay.
Laurent
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi Laurent,
Sorry for my late response. Would you need help in implementing a Kalman filter (or higher order filter) for all the available sensors in iPad 2? I'd certainly be interested to help out of interest. Please email me at emf.gauss@gmail.com if you are interested.
Thanks,
Kyle.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 3,334
