주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.3GHz, 2.6GHz, 또는 2.7GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.7GHz).
561 질문 전체 보기
New battery fails 3-4 months after install
I was using a car inverter to charge my MacBook which I installed a new battery on successfully awhile ago and now something happened because the car inverter is indicating a power error and won’t work and my MacBook battery won’t work either now. Do you think the inverter fried the battery on my Mac? It was a 100watt ampeak inverter and it should be able to power my MacBook just fine. Could it then be an issue with a loose connection of the battery or something? Suggestions welcome. Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Power inverters can be clean or very dirty! You would need to check your inverts specs and maybe even get an oscilloscope to check how clean it is. What is the error message?
Besides the inverter how you’ve connected your Mac to it also matters! Is the inverter a 120/220 AC type or something else? Ideally you would have used a MagSafe charger to power your Mac.
So now the question is whats been damaged here. Does the MagSafe charger LED lit when plugged in and what color is it Amber - under charge or Green - charged? How does the battery and the onboard charging logic look?
Install this gem of an App: CoconutBattery with the charger plugged in take a screenshot of the the apps window and paste it here for us to see 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Eric Swanson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 26
