주요 콘텐츠로 건너뛰기
15.6" Windows 8.1 Laptop manufactured by Toshiba in 2014.
10 질문 전체 보기
Toshiba C55t-A5222 wont turn on
My laptop won’t turn on. The Adapter is fine, the battery is fine. Its charging, the led for charging is solid white but theres no led light showing up for the power. I tried removing the battery and plug and pressing the button for 30seconds-1 min and plugging it back in but it still won’t work.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Try unplugging the battery and turning it on with the battery removed. In some situations, the battery itself will prevent the computer from powering on.
If that doesn’t work, try reseating the RAM module(s). If there is more than one, try starting it with each one individually.
There are numerous things that can cause this type of issue, it’s just a matter of running through each of them to find the culprit.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Roxy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 489
