Mac running slow and fan running at high speed after water spill
I recently spilled water on my computer and did not remove the bottom casing, much less the battery, as I now know I should have.
I am able to start the computer and get to my desktop however at start up the fan immediately begins and the computer loads VERY slowly.
Once completely booted, the same continues. I have turned off all "at start up" settings for all apps.
Here are the stats for my computer from iStatPro and SmartUtility:
**istatpro**
CPU: system - 90% +/-
HD:
U - 79.92 GB
F - 169.8 GB
MEMORY:
Free - 2.45 GB
TEMP:
HD - 85
CPU - 94
Heatsink - 88
Northbridge - 86
FANS:
Exhaust - 6200 rpm +/-
BATTERY:
Health - NAN
UPTIME:
Load average: 8.89, 11.86...
SMART UTILITY:
SMART STATUS: Passed
Since the computer is not able to run unless hooked up to the charger, I am aware I need to purchase a new battery. My next step is figuring out where I need to start in regards to RAM (I think this is where the issue lies in slowness) and the fans (I'm stumped on this one).
Any and all help would be absolutely wonderful.
Thank you in advance!
Tristan
Update
Thanks for the suggestions! It was definitely water that was spilled on the computer. Promise. :) I will be cracking this bad boy open this morning to see what going on. Bc it was water, I'm guessing, as Mayer said, there won't be residue but I will definitely take a good look and let you guys know what I find.
Update
after opening the casing there is visible residue on the motherboard. i will be proceeding to clean per ABCellars.
Update
cleaned motherboard and still having issues with slow speeds and constant fan. will be testing RAM.
Update
i tested RAM and still no good. I am in the middle of AHT. I'm thinking there may be an issue with a heat sensor which is kicking up kernel_task CPU usage.
Update
I have reset PRAM and SMC to no avail. I ran the AHT and got the following code:
4SNS/1/C0000008:TN1D--124
What does this mean?
I have a kernel_task that is eating up CPU usage (over 170%) with over 60 threads. I have reset the heatsink with thermal paste and made sure all things were connected appropriately on the logicboard.
I have also purchased a new battery to replace the old in case that had an effect on performance and there is still no change.
HELP???
Update
After replacing the motherboard and seeing no improvement in computer performance, I replaced the airport card. There seems to be some issue with my airport card connection. After completely disconnecting the airport card connection and reverting to using a wifi usb dongle for internet connection, I have had no more kernel panics. While this is only a temporary fix to the problem, I have a running computer that is now kernel panic free and fully functional/portable.
좋은 질문 입니까?
5 Comments
If you had taken it apart immediately and dried it I would be more inclined to agree with mayer on the water, though not totally. It is the contaminates (ionized minerals, which are salts) that conduct the electricity and do the damage. When you inspect your board you will see how small some of the components are and their connections/pins. Many of the IC pins you really can't inspect for corrosion between them without expensive optics. Flushing and brushing is the cheap and dirty way to remove those things you can't see with your naked eye. Thoroughly cleaning the board as I have suggested is about the only viable solution prior to throwing money at it. From the information you have given your laptop ran fine prior to the spill. Since the spill and you letting it dry it does not. Please read through the water damage tag.
ABCellars 의
i found something that works for me. it's up there ^ in my revised post under the most recent update (at the bottom)
tristan 의
I too have the exact same problem, except mine was a coffee spill. I will be ordering a new airport card and cable and see if one of them fixes my problem. Will post updates when I get the parts in.
Jake D 의
i can say i was having just like the same isssue and i got it fixed by apple https://goo.gl/oaTc3I and lets see if that also works for you .
JuliaGrace Julia 의
thanks a lot. Tomorrow I am going to sale my mac and suddenly exact same problem happened. This was my first blog. First try and SOLVED. It is the airport card connector, that was not properly inserted. Thanks a looooot.
Suman Dutta 의
