주요 콘텐츠로 건너뛰기
The Samsung HLM or HLN series is a line of projection televisions.
29 질문 전체 보기
The picture no longer shows picture yet still has sound. The issue?
The picture on the Samsung Slim DLP TV no longer works. It left suddenly the other day. A few days prior, it began making a slight crackling noise especially when first turned on. The sound is still in tact. Here is the TV info.
Model No. : HL-T4675S
Serial No.: AHE83CMP800808L
Version: PA01
Lamp Code: BP96-01653A (P132W)
BP 88-00633A
Model Code: HL T4675SX/XAA
Please advise of what the issue likely is and how to proceed with fixing it.
Thank you!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
With the cracking sound, I would suspect that the lamp ballast has failed. If you have a spare lamp, try that first. It is possible that the lamp has failed and made that noise. Otherwise, I would suspect the ballast. The ballast is what triggers the lamp to start similar to a starter in the older fluorescent lamps.
Dan
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ray 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 40
