주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1158 질문 전체 보기
Home button sticking after I replaced digitizer
The home key is sticking after I replaced the digitizer on my iphone 3g. It appears to be properly aligned, however, I am no expert at phone repair, so it may not be. The home key is fully functioning, though. What could be causing this, and how can I fix it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
Home button sticking is to vague. What do you mean? Pressing it is not smooth, or a simple push results in multiple clicks. If pressing is not smooth then possibly you placed the digitizer adhesive too close and it is touching the home button. If so clean home button with isopropyll alcohol a bit generous so it can seep down at edge of Home Button and dissolve the missaligned adhesive. Tell me your Home Buttom problem in more detail so we can help you fix it. Brad
댓글 달기
답변 1개
선택된 답변
Open the phone back up, flip the display over and have a look at the gold prongs. They should be raised slightly up from the home button assembly. They are very fragile but if they're a bit flat this may be why it feels like it's sticking
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Mallory Harber 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,015
