주요 콘텐츠로 건너뛰기
Information and repair instructions for GE Freezer
GE freezer(bottom)works fine.fridge is warm
My GE freezer(bottom)works fine.fridge is warm-took all trays out,and inside at back is a panel.took 3screws out ,pulled panel off gently.at bottom is opening,and nice cold air!
Looked at panel.had to unplug it.it has a little door that open and closes .this was shut solidxthus the fridge was not letting in cold air.
Wat do I do now?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Lucky, the little door is a damper door to allow cold air from freezer in to fresh food section. It opens and closes, this is determined by the tempature sensor. When the sensor feels to warm it’ll send voltage to the damper to open. Then to close. You could have a failed sensor or a failed damper. The problem is the back panel. I believe the back panel is nothing more that an air vent with the damper desperate from the panel. Or is the damper part of the back panel? I couldn’t tell in the parts breakdown. The back panel is no longer available. I found no other damper on this model. The sensor is part #WR55X10025. It’s under $25 and worth a try. Cross your fingers and ope all you had wrong is the sensor. Good luck.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Leave the door open and put it back together.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Do u mean leave the baffle open and unplugged,because this will freeze fruit.
Please give me the model number
GE mod.gdsz05bsas5.the z mite b a 2
It is a 2. I thought I might be able to tell by looking at the part but I can't. Maybe @ladytech can help with this one. Here are the parts for your machine: https://www.repairclinic.com/Shop-For-Pa...
댓글 달기
답변을 추가하세요
Lucky 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 189
