주요 콘텐츠로 건너뛰기
Why are my beats x not turning on
My beats will flash white 3 times and appear red when on charger indicating they are charging but they won’t turn on please help I’ve tried resetting but it does not work and the guide on reddit was way to complicated
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
Beats x on charger ….keeps blinking red to white ……will not turn on
댓글 달기
답변 2개
가장 유용한 답변
I would try updating them. It might be a simple software issue. Otherwise it would be that the port is damaged.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
I’ll check to see if that works thanks for the help
I tried updating them and I know there charging because the light turns on and the firmware update didn’t work
Same issue. Apple support says they are defective and wants $80 to replace them since mine are 14 months old. Crappy product and poor support.
Mine are still under warranty I got em in December
댓글 달기
You are a doughnut fool !$$&* you need to use a Samsung charger not an iPhone charger go to auction to get a username which has £200 minutes in the account mohamedrashid00
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Silentgunner COD 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 11
전체 시간: 18,314
