이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Just cutting some of the legwork.
P065C - Generator Mechanical Performance
if i understand it correctly, 5v+ pcm output that turn on the voltage regulator for the alternator
P0427 - Catalyst Temperature Sensor Low (Bank 1)
Followup questions: is the alternator charging properly, is there any oxidation on the ground braids or points, or is there any visible scuff marks or worn/brittle cables, and an easy one..is there any sockets that's disconnected?
David 의
