Computer Will Not Boot in any Mode
I have tried resetting ram and smc.
I was using garageband when my computer froze all of a sudden. the music kept playing it was eerie. I force shut down and computer no longer boot up in any mode. after I did the ram and smc resets, I tried to do recovery (and in verbose) and I get a log that says disk0s2: media is not present.
failed to open swap file 6. va_swap_create_file failed.
then goes to a bright screen. I turn it off at this point.
If I allow it to try to boot normally or to recovery it just loads for a long time til it gets halfway and it appears to stop there so I cannot access diskutility.
Is this the ram failing or the hard drive failing? Thank you for your time and input.
Chris
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Do you still have the grey disks that came with your system or the retail copy of OS-X?
If not, do you have access to another Mac and a USB or FireWire drive so you can create a bootable drive?
Some how you’ll need a means to boot up you system to fix the drive and you may need a new drive.
댓글 달기
