주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.4GHz, 2.7GHz, 또는 2.8GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.8GHz).
Is this SSD compatible and do I need an adapter?
I just ordered the following SSD for my early 2013 MBP Retina 15". I've read some say it's compatible, some said I need an adapter and some said it's compatible but then need to download drivers. Is anyone able to assist?
Samsung 960 EVO Series - 500GB NVMe - M.2 Internal SSD (MZ-V6E500BW)
https://www.amazon.com/gp/product/B01M20...
I was told this adapter is what I would need.
https://www.amazon.com/Adapter-MacBook-R...
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Lets start off on the SSD’s connector, The Samsung 960 EVO is a NVMe M.2 drive. Your Mac uses a custom physical SSD interface so these will not mate directly!
The drive dialog of your Samsung SSD is PCIe/NVMe but your MacBook Pro is expecting mSATA III (6.0 Gb/s) interface drive. So this drive will not work in your system even with the adapter you’ve linked to.
To help clarify things, review this diagram:
Your system uses the Purple path on the left. Here is a great reference on what Apple used for SSD’s The Ultimate Guide to Apple’s Proprietary SSDs And your system uses the second generation of SSD’s (GEN2) within this guide.
If you can, I would cancel the order and look at just getting the correct SSD to start with from BeetsTech (or any other good source like OWC or Transcend) in the long haul its just gets you a better outcome.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Christopher C Stone 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 215
