My car quit running and will not stay on
My 2006 was running then it started to putter and then i t quit. And will not stay on, they think the coils burnt out and they are replacing the end is this the solution.
좋은 질문 입니까?
좋은 질문 입니까?
The only solid advice I can give you is - Fuel, Air and Spark. These are the 3 vital components needed for combustion. So take into consideration what components such as fuel injectors may be failing. Maybe the injectors are clogged up and need cleaning. Check that your fuel filter is not clogged and not dirty. Check that your air filter is relatively clean and not completely full of crap and finally check the spark plugs. Take them out of the engine head (with the cables still attached to them) and lay them on the engine head or something grounded and conductive and turn the engine over. If they spark then great, you know it's not the plugs, if they don't, try replacing them and see what happens. Good luck.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 6
30일 전: 14
전체 시간: 130
