주요 콘텐츠로 건너뛰기
Released in 2011, the M17x R3 is the third revision in the Alienware M17x line of gaming laptops. It has a 17-inch screen, 2nd-generation Intel Core processor, and a discrete graphics card.
1 질문 전체 보기
What’s Gone Wrong With My Alienware Laptop Screen Display
Hi guys,
This problem starts a quarter down the screeen & gets worse from left to right:
https://i.imgur.com/L2FgAXj.jpg
It rarely disappears for a minute or so.
If I plug in an HDMI TV it doesn’t have the problem.
Thanks for any insight.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi,
There is a problem either with the connection of the video cable between the motherboard and the display at either end, the cable itself (does the problem come and go if you move the lid back and forth?) or the screen itself.
Here’s a link to the service manual for your laptop.
Scroll to p.71 to view the necessary pre-requisite steps and then the procedure to remove / replace the display. This will help you to first gain access to where the display cable is plugged into the motherboard to check that it is seated properly. If it appears to be OK then you’ll have to continue with the procedure and remove the display cable and the display to investigate further.
Here is a link to just one supplier of a replacement screen. It is not a recommendation to use them. It is shown just to give an idea of the cost of the part.
There are other suppliers online that may suit you better. Just search for Dell Alienware MX17xR3 lcd screen to get results.
Hopefully this is of some help.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks.
I was going to try replacing the cable but while searching for one I stumbled across this cheap monitor. Replaced it and it’s good as new.
http://s.aliexpress.com/UR3222ue
댓글 달기
귀하의 답변을 추가하세요
Stephen Shaw 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 1,211
