주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Incorrect password and unable to join
i got 2 iphone 6s that i bought from a person and he said to me they work fine but they don't connect to wifi nettworks.
So i got them i have DFU restored both of them - SAME PROBLEM
I have changed their wifi anntenas - SAME PROBLEM
I have cleaned their motherboard with alcool - SAME PROBLEM
so i decided to ask you guys if you have any knowlege about this problem i know it's motherboard fault but i'm not good and finding problem by myself.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
The phones are iCloud locked. You’ll need to ask the seller to unlock them if he can’t then return them and get your money back as they are likely stolen!
And No there is no way to unlock them. Think of it this way… You have an egg in your hand without cracking (opening) the shell open can you get whats inside out? Nope!
Same here you can’t get in without breaking the iPhone.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
They don't have icloud account open i mentioned that i have restored them with itunes in DFU mode they started like every unlocked iphone
Anyway thanks for your contribution
DFU mode does not undo the iCloud lock. All you've done is refreshed the phones firmware if needed
So I assume these phones have passed the activation setup page.
Is the Wi-Fi able to turn on? Or is it stuck greyed out off?
@danj If you hard reset the iPhone and it has iCloud and find my iPhone on you just can't pass the activation setup page. They passed it as they don't have iCloud lock.
@benjamen50 The WiFi turns on and its range is perfect but in every router that i want to connect even with password or no password the popup just shows up and says "Incorrect password" or "Unable to join network"
댓글 달기
Help! I have the same issue and my iPhone is brand new from o2 the day they were launched so I know it’s not a knock off!
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Bring your phone to an Apple Store with your sales receipt.
It turns out your phones ID may have been stolen by someone! Basically, they used a utility Apple made available a few years ago to find unused Phone ID's to use on their phone. So when you tried to setup via the activation setup page it won't work!
how to get back phones id if u don't have an apple store nearby
댓글 달기
귀하의 답변을 추가하세요
Adrian Zymeri 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,718
