주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Does not power on. Error 40 when trying to restore
Hi guys,
I have couple of iPhone 5s which do not turn on. When I try to restore it gives error 40.
I have checked some power lines already:
PP_VCC_MAIN
PP_BATT_VCC
PP1V2_CPU
PP1V0_SOC
PP1V2_SDRAM
PP_1V0_SRAM
PP5V0_USB_PROT
PP1V8
PP3V0_NAND
PP1V2_NAND_VDDI
Those are all present. But I have couple of lines that are missing:
PP1V1_GPU and PP3V0_ACC.
Are those lines required for the boot or to complete the restore? Thank you.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Hi Ben,
Thanks for a quick response. I found out already that PP3V0_ACC does not impact charging but does it affect boot or when trying to restore? Since PP3V0_ACC and PP1V1_GPU are created by PMIC I probably should suspect it first?
댓글 달기
답변 1개
가장 유용한 답변
Credit goes to Jessa at iPad Rehab, made a summary below of video:
PP3V0_ACC (From U2 Tristar chip [ACC_PWR], Pad D5 is location of it under chip) is used for powering lightning accessories (usb fan / HDMI adaptor / unusual stuff) from the lightning dock connector.
Phone will still charge normally without PP3V0_ACC with iPad / iPhone wall chargers and USB connection to computer still works.
Source for PP3V0_ACC explained:
https://www.youtube.com/watch?v=OsIKeFnd...
Below is potential solution from a GSMhosting thread
For PP1V1_GPU short it could be caused by U7 (Power Management chip)
Removing l13 and l14 I assume can be used to confirm if U7 is causing short.
Source for PP1V1_GPU short solution at Post #2 of thread post:
http://forum.gsmhosting.com/vbb/f631/iph...
Edit forgot to say with PP3V0_ACC missing the phone will charge half speed if a USB ammeter is used. 0.9ish-1.0 Amp is expected charging speed for normal charging.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi Ben,
Thanks for a quick response. I found out already that PP3V0_ACC does not impact charging but does it affect boot or when trying to restore? Since PP3V0_ACC and PP1V1_GPU are created by PMIC I probably should suspect PMIC first? L13 and L14 are not short to ground.
댓글 달기
귀하의 답변을 추가하세요
Karolis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 428
