주요 콘텐츠로 건너뛰기
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
227 질문 전체 보기
Enclosure for iPod classic hard drive
Power source for iPod Photo 4th Gen (60gbs) died. I tried replacing battery but no joy.
Is there an enclosure or adapter o can use to transfer songs off the drive and then format as either a portable hard drive or as additional storage on a Mac Pro?
James C.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
You can access this ZIF drive using a Universal Adapter:
Universal Drive Adapter
Universal Drive Adapter 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
It may be the hard drive which has failed. If so your out of luck. You can still get some use out of it with this cheap fix
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Avais -
Thank you for your reply and attached solution. I was assured by the guy that diagnosed my iPod that the drive was fine, it is just the power module is defunct.
Regards,
James
댓글 달기
This is exactly what you need: ZIF HDD caddy: https://amzn.to/42furqD
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
James Coogan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 15
전체 시간: 496
