주요 콘텐츠로 건너뛰기
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
knocking noise on spin cycle
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Cause 1
Rear Drum with Bearing
The rear drum has a bearing or bearings in it to keep the inner tub spinning smoothly. If the tub bearing system is defective the washer can become very noisy. On some machines bearings are sold separately from the rear drum, however we recommend replacing both the outer drum and bearing as an assembly if the manufacturer offers the components together because removing and pressing in the new bearing can be exceptionally difficult. Be aware that replacing the outer tub and bearing is also not easy and can be very costly.
Cause 2
Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing.
Cause 3
Tub Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing as an assembly if the manufacturer offers the components together.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
jimfelice 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 654
