주요 콘텐츠로 건너뛰기
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
127 질문 전체 보기
Stick drift persists after adjusting the sticks
Hey guys! I've been having bad upwards stickdrift on my right stick, so I took it apart and adjusted it to nearly completely remove it. It was fine. A bit of tiny downwards drift, but barely noticeable. Not long after, the drift has returned. I going to have to rip it apart and asjust sever times a day, or am I just doing it wrong?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Which model is it?
Sorry, I should have specified. 1708. The white one.
댓글 달기
답변 3개
가장 유용한 답변
You can try cleaning the stick with 99.5% isopropyl alcohol, this has helped me with the same issue in the past, just dab it in with a Q-tip, and clean.
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
That was the first thing I tried. Before I tore it completely apart to adjust it.
I'm also getting double inputs on YouTube and Xbox dashboard of that helps.
Hm. Hard to tell, with the double inputs, did you by chance get the controller wet? or spill anything on it?
No, not that I know of. The double inputs seem to be linked to the control stick though. Whenever I adjust it to remove the drift, the double inputs go away, but they return as soon as the drift does
Could it be the sensor that I've been adjusting? If I put a new one in there, might it work normally?
A new sensor might fix the issue, however, be careful with the soldering. If there is damage to the logic board of the controller, it will persist.
댓글 달기
The way plenty of people fix stick drift (including myself) includes the following.
  • Cotton Bud
  • Rubbing Alcohol
  • Controller
  • Wet the cotton bud w/ the RA then tighten it up/ squeeze the end, reapply RA then rub it all around the joystick as hard as possible
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
what the heck is a RA?
댓글 달기
I just fixed this on my elite controller and the way i fixed it was by separating the up and down green piece a little. Hard to explain but after you get your controller apart there are 2 green pieces. One for up and down the other for left and right. My conclusions is that the piece is worn out so it's loose. Separate the green piece on the right just a little bit so the black prong on the side go in a little. This worked for me and nobody told me about it
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Can you use the lens cleaning wipes because it says it contains isopropyl alcohol so can I use that
댓글 달기
귀하의 답변을 추가하세요
Mark Whittaker 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 14
전체 시간: 7,172
