Can I replace my HDD with an SSD
I have a MacBook Pro (17-inch, 2.4GHZ) with a dying hard drive, can I replace my HDD with a SSD? Will any SSD fit or there's certain specs that I need to be shopping for?
Thanks ahead for any help.
좋은 질문 입니까?
좋은 질문 입니까?
This is probably your machine:
https://everymac.com/systems/apple/macbo...
If so, it has a SATA I bus. 1.5 Gb/s. Most SSD drives are are 6 Gb/s. So make sure the drive you selects backward compatible to SATA I.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 4
30일 전: 10
전체 시간: 159
댓글 1개
Are you sure of your model? The model you've picked is the older Core2Duo. I'm thinking you have a newer 17" model, a late 2011 here's its specs: MacBook Pro 17" 2.4 GHz i7 (Late 2011) and here is the correct IFIXIT group: MacBook Pro 17" Unibody
Dan 의
