주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Error 4014 when restoring iPhone 5S
Hi, I completed a screen replacement on this phone, thinking the display was non-functional only to realize the phone was in recovery mode. I connected the phone to iTunes, completed the restore and applicable updates. The phone seemed to work fine after that, was a little warm when charging but I've seen that before with other phones. I charged the battery to 100%, unplugged and left overnight to test battery life.
This morning, the screen was black and phone was unresponsive. I connected to iTunes again, and got the message that the phone was in recovery mode again! I proceeded to restore the phone again and begin troubleshooting but once iTunes was able to bring the Apple logo onto the phone, the phone turned off and I keep getting error 4014. I've tried multiple cables that I know are working. At one point, the Apple logo appeared, the screen turned red then turned off, once again with error 4014.
Has anyone experienced this before? I'm just curious if I should be investing a lot of time into this phone if it's a big job to fix. Thanks for your time!!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
It's probably booting up into DFU mode, you can confirm this by pressing on the screen and see if you can see white marks appearing meaning the screen is on but displaying a black screen.
Also you can use 3UTools to check this too. Whenever I get iPhone 5s's that have the exact same symptoms like yours, I've never managed to fix the problem.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Phone tech 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 1,583
