주요 콘텐츠로 건너뛰기
E-Cigarette Vaporizer/전자 담배 무화기는 재사용이 가능한 기존 흡연의 대안 제품입니다.
121 질문 전체 보기
G Priv Baby Luxe Bricked, need 1.0.1 Firmware
Similar to a guy I saw on here with a T-Priv 3, I bricked my mod after doing a firmware update wrong. I require the stock firmware for a G Priv Baby Luxe in order to get my baby working again, any help would be amazing.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 3개
I have the same issue and in search for the stock firmware for this mod.
Hi. I found a great place where I can get all the vaping products I need and I thought I should share it with everyone.
It’s called Vaperite. Check them out https://buff.ly/3P5BF9b
Gwam stands for Global Wholesale and Marketing and it is an online store that bridges the gap between you and products from all around the world.
The exclusive distributor for our esteemed products <a href="https://gwam.pk/product-tag/wape/">Aroma King</a>,<a href="https://gwam.pk/product-category/pods/sm...> Smok</a>, <a href="https://gwam.pk/product-category/pods/vo...>Voopoo</a>, and <a href="https://gwam.pk/product-tag/caliburn-pri...>Caliburn</a> is Global Wholesale and Marketing (Private) Limited. It is renowned for providing the best import services in recent years and brings all varieties of pods, vapes, and energy drinks to your table in high-quality.
댓글 달기
답변 10개
가장 유용한 답변
Thanks to Danillo for solving this problem.
To revert your currently brick mod back to the stock firmware you need to download the Nuvoton firmware update software from Smok’s website and the original firmware bin file.
Remove the battery from your Smok device
Open Nuvoton NuMicro ISP Programming Tool 2.00
Hold the fire button on your Smok device and connect to you computer using the micro-usb cable (you have to hold the fire button during the entire process)
Once device is connected to the computer you should get a device connected notification on your computer. On the Nuvoton window click Continue and then Connect on the next screen
Click on APROM and select the stock firmware .bin file you have downloaded and ☑ the following
Click Start and your device should be fixed
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thanks a lot..
댓글 달기
I have the same issue, I think I installed a G-Priv II 1.0.5 firmware instead and now it won't boot. is there a way to format it back to 1.0.1?
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Do you fix your proplem i had de same issue
댓글 달기
Does someone has a solution for this? Where to download the original firmware?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I made the same mistake. I have emailed smoktech support. Has anyone still found any solution?
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Apparently smok after sales service told me to install the firmware! Where the Effin Eff is the firmware? Bunch of idiots!
댓글 달기
hola he cometido el mismo error que necesito la solución wtf
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hallo habe die original Firmware für die G-Priv Baby! Kann sie per E-Mail zukommen lassen!
댓글 달기
해당 답변은 도움이 되었습니까?
점수 1
댓글 15개:
please send to me edwinval.reyes@gmail.com
can you email it to me too ?? jimilvineyard96@hotmail.com
please send to me, please : totti953@hotmail.com
please sent it to me yunghoe23@gmail.com
I need it please! eduvicma@hotmail.com
댓글 10개 더보기
댓글 달기
yea, and dont forget to send it to me pls!!!!!!!!!!!!!!
yveso45@gmail.com
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Can you plz send to me too...
Dventura517@gmail.com
댓글 달기
May I have the original firmware sent to me as well please. for the gprive baby lux email to forever4lala@gmail.com
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
do you have firmware E-PRIV
댓글 달기
arslanfurkan999@gmail.com
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi, pls send for me too
barthagery@gmail.com
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
knroo6 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 19
전체 시간: 5,783
