How to properly glue the display
What is the best method in resealing the LCD display back down? I have applied the double sided tape, is there anything else that I need to apply?
Thanks
좋은 질문 입니까?
Thanks
좋은 질문 입니까?
Hey Dustin
The best method to reapply the LCD screen on the iPad is to use the adhesive strips that are custom fit to the iPads frame. These adhesive strips work the best. If you don't have adhesive strips you can order them pretty inexpensively here on iFixit or Amazon.
Double sided tape doesn't really work that great since the tackiness of the tape becomes weak over time. This results in the display becoming loose and popping up. After applying the strips its recommended to use a heated pad or heated pack to help secure the adhesive to the screen (iFixit also sells this tool).
Hope this helps good luck!
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 83
