주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
759 질문 전체 보기
MBPro starts but screen dead
Hi!
When I press the start button on my MBPro I hear fans, DVD, HDD rev up and power led behaves as it should, but that's it. I hear no startup chime and the screen doesn't activate at all. I have tried SMC reset, I have tried to start it with power adapter only (adapter is working, I use it on my other MB) and I have checked that the RAM is mounted correctly. I removed the hard drive and connected it to my other MB and it works correctly, so luckily I can do a back up of it. Do any of you have any suggestions what I could try next?
Sincerely
/Fredrik
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
Try Hooking it up to an external display. See if you get anything. If not then reset the Pram, when its starting up press ( option-command-p-r) Until you hear two beeps. If that still doesn't work try removing one stick of ram it could be corrupt (but highly unlikely).
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I'll give it a try. Thanks!
No luck :-( External display doesn't react at all, PRAM reset did nothing and I tried with a couple of other RAM sticks that I know are working.
댓글 달기
귀하의 답변을 추가하세요
Fredrik Lundin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 750
