주요 콘텐츠로 건너뛰기
Portable wireless speaker with a built in microphone. Released January 27th, 2014.
36 질문 전체 보기
Batería de 5 cables
Hey! How are you?
I want to know why this battery has 2 black cables, 2 red cables and 1 white, because i wanted to put another kind of battery that only has 1 black cable and 1 red cable
Hey! Cómo están?
Quiero saber por qué esta batería tiene 2 cables negros, 2 rojos y 1 blanco, porque le quería poner otra batería que tiene sólo 1 cable negro y 1 rojo
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
my guess would be the 2 red are positive the 2 black are negative and the white is possibly data, possibly 1 red and 1 black are charge lines
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Man, i didn't ask that, i asked why has 2, i know black is negative, red is positive.
So, why has two cable positive and two cable negative
I thank you for the cable white, i didn t know that.
For some reason has two cable red and two red,
Is it that has two different voltage?
as i previously said it could be to do with charging
댓글 달기
귀하의 답변을 추가하세요
Severino Alcantara 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 23
전체 시간: 501
