주요 콘텐츠로 건너뛰기
Galaxy S7 Edge는 Samsung의 2016년 주력 휴대폰 Galaxy S7의 곡선형-스크린 버전입니다. 2016년 2월에 발표되었으며 3월 11일에 출시되었습니다. 모델 SM-G935.
369 질문 전체 보기
Loudspeaker hissing and "snow" noise
Repaired a customer’s S7 Edge screen and the loud speaker stopped working. Customer brought phone back when the new part came in and I noticed when it was dropped off that the loudspeaker was making a hissing noise and sounded like snow on a TV. After replacing loudspeaker, the problem did not go away. I had a spare S7 Edge at the shop (as all it does is bootloop), took the loud speaker out of it, and tried the 3rd speaker with customer’s phone- same problem.
Everywhere I look, the answer seems to be software/app related. I looked at the board, and compared it to other boards. No signs of a burn or short or missing chip/bent prong, etc.
So, to recap, his original speaker stopped working after screen replacement. He took the phone with him until parts came in. When he brought it back, the loudspeaker was making a hissing noise. Replaced loudspeaker with new part- still hissing. Tried another part from a different source- same problem.
Any suggestions?
Thanks in advance!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hello,
The only cause I can see is either a software problem, then maybe a factory reset could help, or a component from the motherboard that is causing this problem.
I hope it helped you a bit
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Trevor Brodie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 13
전체 시간: 305
