주요 콘텐츠로 건너뛰기
Weber Grill Pressure Regulator Diagnosis / Replacement
Trying to figure out what is wrong with a older model propane grill made by weber. someone cranked on the plastic collar , attached to the pressure regulator with a wrench . i dunno why. I suspect the compression fitting i guess for the pressure regulator will not work correctly now , maybe cracked from using a wrench for no reason.
grill was working perfect before this now no smell of propane , appears to have no gas flow . Part of the problem is i dunno / remember what the model is . I have attached a few more pics below.
if i am correct , i just need a new pressure regulator , so if anyone has any ideas on what a “good” compatible model or just weber OEM one i could buy it would be appreciated.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
See if helps nail down the problem Propane Grill Regulator & Hose Replacement
Do be careful! Propane does not have an odor additive like household gas does.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
i followed most of the info in this guide, having reinstalled the regulator, turning gas on and waiting and so on . Grill is now working, no model info on my grill afaik. so glad its working now , thanx for help
댓글 달기
If I remember correctly, there were changes made in propane regulators about the mid-ninties https://www.google.com/search?client=saf...
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
ty, i will try this, using the existing regulator over next few days , it not being OEM i dont have a part #. This partially why i am on ifixit to try and figure out which OEM or just good aftermarket regulator i might need . My grill is 5 flavorizer bar model with two controls on side , a few models it could be via this website: https://www.thebbqdepot.com/blog/which-w...
댓글 달기
답변을 추가하세요
Brian 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 21
전체 시간: 1,853
