주요 콘텐츠로 건너뛰기
Released in November 2017, the Oppo F5 is the first smartphone to use an 18:9 display instead of 16:9. In spite of having a 6.0-inch screen, the F5's width is similar to the 5.5" display with 16:9. Models CPH1723 and CPH1727.
Low Brightness even when adjust to full brightness
How can i improve the brightness. Its way too low compared to my friend’ s oppo f5
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 9
댓글 5개
My mobile oppo a83 this screen low brightnes plz help how full brighte screen light plz help me
i have oppo f5 how to increase the briteness
My Oppo A31 display brithness is too low after firmware flash. Pls help me
My oppo a3s low britness help me
Kenapa ketika ada warna putih langsung kedap kedip layarnya dan suka lama matinya
댓글 달기
답변 2개
가장 유용한 답변
Check if the Battery saving mode is ON or OFF.
If it is on you are limited on level of brightness you can select.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
it's off. have another solution
댓글 달기
You Hold the 3 buttons at a time power button , lower volume button and home button and you to restart the mobile
that will help any of the problem of the mobile
Thank You
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
andresasedillo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 13
전체 시간: 3,566
