주요 콘텐츠로 건너뛰기
식기 세척기 수리와 분해 안내서 및 지원.
706 질문 전체 보기
Drains without dishes... but not with
I have a slightly aged Indesit dishwasher. I ran a program a while back, it completed the rinse cycle, but did not drain and therefore finish the cycle.
Syphoned out the water cleaned out some muck and ran a dishwasher cleaner, without dishes. Ran two full cycles and everything seemed friendly
Have just run a cycle with dishes ones again and we are back to square one.
Any help greatly appreciated!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Cause 1
Drain Pump
The drain pump uses an impeller to force water through the drain hose. If the drain pump motor is not working, the dishwasher won’t drain. To determine if the drain pump is defective, check the pump motor for continuity using a multimeter. If the motor does not have continuity, or if is getting power but won’t run, replace the drain pump. Drain pumps are not repairable—if the drain pump is defective, you must replace it.
Cause 2
Drain Impeller
The drain impeller pushes water through the drain hose and into the garbage disposer or drain line. If the impeller is broken, replace it.
Cause 3
Drain Solenoid Kit
The drain solenoid opens the drain valve to allow the water to exit the dishwasher. If the drain solenoid fails the valve will not open causing the dishwasher not to drain.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks for the thoughts above. However, this doesn’t answer the query of why it drains when there are no dishes in the tray, but does not drain when there are?
댓글 달기
귀하의 답변을 추가하세요
David Sturgess 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 55
