주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
iPhone 6s (model A1633) Bluetooth Not working
As the title says, my Bluetooth is not working. I’m having trouble finding a replacement Bluetooth antenna. A competing web site shows the wifi antenna also containing the Bluetooth antenna. ifixit doesn’t list Bluetooth in the description of the wifi antenna.
Bestbuy offered a guess it might be the logic board….idk. The battery has been changed to an ifixit battery, and they also said that may be hindering its ability to work. LOL
Does anyone have any advice on how to fix/troubleshoot the Bluetooth?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
I have had bad luck with ifixit batteries in the past, but I seriously doubt that is the cause of your bluetooth issue.
If you are also having issues with WiFi it could be the actual IC, as the same chip controls both.
Check your antenna connections at the top left (weird looking bracket on the logic board above the pwr/vol flex), and bottom right (diversity antenna sitting on top of the loudspeaker)
If all of that fails, it also never hurts to try a DFU reset. If you’re still having issues at that point you might need some board work done.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Is WiFi grayed out or is it just not finding anything? I will say I cannot think of a time where the actual antenna itself went bad, its too simple to really fail. WiFi module or boosters on the other hand could absolutely fail.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dean Fritzel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 120
