주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
MacBook Pro does not power on
Good day,
I have a Mac Book pro that i upgraded and after the upgrade, when the laptop is turned on it chimes but then stays on a white screen. Also sometimes it does not even turn on. Even though the magsafe is green and is connected and the white light to the bottom just flashes. Any idea of what can be this issue?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
What was the upgrade?
not sure. its a customer's laptop
댓글 달기
답변 2개
가장 유용한 답변
This is usually caused by the hard drive or hard drive/IR cable. Pull the drive and hook it up to a USB to SATA adapter and see if it will boot externally. If it will see if the drive is formatted GUID. If it won’t boot try booting externally with a hard drive with a compatible system installed on it.
I always replace the cable on this model as it is a know issue.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It could be a RAM compatibility issue. Try testing each RAM in each slot or use another set of RAM that are known to be working stable.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
MICHAEL JABARI NELSON 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 55
