주요 콘텐츠로 건너뛰기
카세트 플레이어의 수리 안내서 및 지원.
high pitch sound when play button is pressed
when play button is pressed down there is a high pitch sound, when the volume button is turned low it disappears and then when on high it is a high pitching noise.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
My cassette deck emits a high-pitched squeal as soon as it is turned on, without a tape installed and in play mode. Any thoughts on the cause of this?Thanks.
댓글 달기
답변 1개
가장 유용한 답변
This is a common problem that is usually resolved by cleaning an internal multi-bank switch. The problem is a feedback loop that is caused by dirt/debris inside the switch which connects a couple of circuits that should be separated. Open up the unit and spray all switches with a lubricating electronics switch cleaner. Engage the switches multiple times and the problem should be resolved.
Dan
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
ddmcsp 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 35
전체 시간: 2,893
