주요 콘텐츠로 건너뛰기
An Android digital 9'' tablet, made by APEX.
What should I do if the motherboard capacitor is broken?
When I opened the case to clean the dust today, I found two capacitors violent, (it reads fz57 150 6.3V)
Excuse me, what should I do? ? ?
What effect does the two capacitors have on the computer? ?
(Currently everything is normal, in use)
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Not knowing where these fit in the scheme of things, I can guess that these are likely filter capacitors that eliminate noise on the DC supply line. If this is the case, then replacing them is recommended as these will help to protect hte CPU as well as prevent the “logical maybe” which occurs when the voltage fluctuates. These are most likely surface mounted devices which require a bit of experience to replace. Get them replaced.
Dan
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
thank you for your help,i will try it.
댓글 달기
답변을 추가하세요
Annaa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 181
