주요 콘텐츠로 건너뛰기
The Xbox One Wireless Controller model 1697 was released in 2015 and replaced the model 1537 controller and fixed some of the problems found on Model 1537 controllers. The Model 1697 controller includes an integrated 3.5mm headset jack, which allows compatibility with most 3rd party headsets without the need of an adapter. This controller has been discontinued and replaced by the Model 1708 controller.
74 질문 전체 보기
Why is my right trigger always activated even when i'm not pressing it
My right trigger has been like this for a year now i am going to open it up once i get the tools and i am wondering if anyone knows what is wrong and how to fix it.
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
If the right trigger is faulty . When you open it up , you will notice that the trigger makes contact with part of the board ,it may be spring that the trigger makes contact with maybe faulty or maybe need to be cleaned out .if u do open it up try n use 99% alcohol to clean it out of it is messed up . Also the part the trigger makes contact with may be going bad especially if it acting with out you touching it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Would Lysol Disenfectant spray work?
댓글 달기
What I do is hit the RT or the faulty button really hard with my hand and after a few times, it worked. Not that I necessarily recommended this as the problem does come back occasionally. Do this at your own risk
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Wtf i just gave it a shot and it actually worked, thank you ive been tryna open it and I don't got the torx screwdriver I was looking around for a bit then I decided to look online and boom seen this and I gave it a wild shot and it actually worked like wtf so many controllers I got rid of I could've just done that😂
댓글 달기
귀하의 답변을 추가하세요
Bailey Smith 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 10
7일 전: 58
30일 전: 373
전체 시간: 16,639
