주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2015년 5월 업데이트에는 5 세대 Intel Core i5 및 i7 프로세서가 성능과 배터리 수명을 약간 향상시켰습니다.
623 질문 전체 보기
Not Charging- Tried two batteries and two power adapters
Hello,
Swapped out the battery on a Mac Air 13 inch early 2015 because the battery was not charging.
Tried SMC reset.
Put in a new third party battery, does not charge either. Third- party battery came with 35% charge thankfully, so will power on, and coconut battery shows the battery is in good condition but just will not charge, and it recognizes that it’s plugged in.
Ive tried both a 45w and a 60w adapter for the device, and neither will charge the computer.
Mac will power up on adapter only with battery completely removed. During this step, the light on the magsafe was unlit.
The light *was* on both power adapters, showing orange. Sometimes it will be orange and sometimes the light will not come on at all, but the mac will power up just fine.
Logic board replacement? Not sure what’s causing this.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The charging logic on the main logic board has a problem. A good Mac repair person can fix this. Or, you could replace the logic board.
I would recommend you check your MagSafe adapter & the DC-In Board. Review this Apple T/N: Apple Portables: Troubleshooting MagSafe adapters. Also Make sure you are using a real MagSafe adapter! There are quite a few fakes out there now. Lacking safety features, cheap MacBook chargers create big sparks
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I appreciate the response. As this is for a client (trying to take side jobs while in school) I will recommend we replace the logic board.
I am not well versed enough to do any soldering work to fix the issue, nor could I find any .brd files for this model to work with OpenBoardView to make a valid attempt.
I do wonder how many repair shows actually do their own soldering work versus replacing the entire board? I wonder what the cost difference is.
Its a common enough issue ;-} Louis Rossmann has done a few YouTubes going over the issues. Its a lot cheaper repair.
댓글 달기
귀하의 답변을 추가하세요
Jessica Weber 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 116
