주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.4GHz, 2.7GHz, 또는 2.8GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.8GHz).
274 질문 전체 보기
MacBook Pro A1398, 820-3332A Logic Board TSOP Error
Hello,
I have a 2013 Macbook Pro 15. 10 seconds into the bootup the fans go full throttle, the MacBook is slow to boot, and once it does manage to boot the CPU is > 100% at all times.
  • Ran AHT, it reported – 4SNS/1/40000000 TsOP—124
  • Bought a new trackpad with cable, replaced. No change, same issue.
  • Removed the logic board, cleaned everything and reinstalled. No change, same issue.
Any suggestions / help would be deeply appreciated. Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Check the logic board thoroughly for damage; blown components or damaged sensor circuits can cause this issue. Test it will just the charging port, fans, SSD and trackpad connected; if the fans still go full speed it will be logic board related.
If it is logic board related, I would suggest taking it to a repair centre to check out; a decent repairer will know areas to check and will determine what is causing the fault.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Mandeep Singh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 190
