주요 콘텐츠로 건너뛰기
Repair guides and support for Kenmore washing machines.
will not fill with water when set in cold
I have a series 100 Kenmore washer it will not fill with water when set in cold but works on hot and warm but does not fill up but half way or less what is this issue there us no water level setting
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Sounds as if your cold water valve is clogged. There's no way to work on the valve, only replacement will cure it. Call customer service and they will make it right for you under warranty.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
dwaynekmallory 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 39
