MacBook Pro takes hours to turn on after battery drain
So I was recently away for about two weeks and I left my laptop and home and did not use it, I left it unplugged on a flat surface for those two week and when I came back and tried to turn it on it acted like it had run out of battery (understandable) but I tried to plug my charger in and the charging light did not turn on and the computer would not power up, I tried to figure out different ways to fix it and one of the times I just plugged it in and it just started charging out of no where, it didn’t seem like it was something I did, just chance and then it power up and started working.
I have rest the SMC multiple times, tried using the battery to 0 and then charging it back up but it seems then whenever it runs out of battery all the way which happens when I don’t use it super frequently it takes hours for the little light to turn on and for it to start charging again and turn on. I can’t seem to figure out what makes it charge again it just starts out of no where I’ve tried many outlets and chargers and it’s not them I bought this computer a little under two years ago and I don’t understand why it’s having problems so soon? please help thank you!<33
좋은 질문 입니까?
More likely your battery is worn out. download this gem of an app: CoconutBattery take a snapshot of the main window and post it here for us to see 기존 질문에 이미지 추가하기 That will allow us to figure out what you'll need to do.
Dan 의
I had a similar problem with my Macbook, with one of those multi-terminal, oblong charging jacks. It turned out all I had to do was clean the charging port with one of those Nylon, small round cleaning brushes. They look like a mechanical pencil, about 3/16 " in diameter, and there is a Nylon cleaning brush that feeds through as it wears, and then clean both the Port (On the Laptop) and the connector (From the charger) with a fine cleaning cloth (Computer screen cleaning pads will work), soaked in 30% Isopropyl
Alcohol.
capone99 의
