주요 콘텐츠로 건너뛰기
Repair information for 2Boom speakers.
10 질문 전체 보기
2 Boom bx320 Not Connecting to Bluetooth
I’ve been trying to find something online even an instruction manual but it seems no matter what I type in, nothing pops up. My question is, is there a way to factory reset the speaker. Keep in mind it’s not a power button but a power switch on it so I can’t try anything with that.
It used to work just fine and then it randomly decided to stop connecting bluetooth. It doesn’t even show up on devices available to find. Any help would be much appreciated
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 9개
hello there
does it have a clickable volume button ?
Yea, and a pause/play button.
Can you give us a bit more here, who makes it? Can you post some pics so we can see the unit? 기존 질문에 이미지 추가하기
Also, it's made by 2Boom and the model number is BX320
I also have the same problem! Have you gotten any word from the 2boom website? I haven’t yet!
댓글 4개 더보기
댓글 달기
답변 4개
가장 유용한 답변
Hold both volume buttons down. Then press bluetooth button box should cut off turn power on then u should be good to go
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Thanks. Worked for me.
What if it's an "no volume button"..?
It has no volume bottom. How do you reset it?
댓글 달기
I had this same problem but all I did was turn it down && it started working , it kept cutting off after it connected to my phone but I started playing around with it that didn’t work either but I turned it down cause I remember getting notifications about it being too loud if you have a iPhone you know what I’m talking about but I tried it && it worked
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Here’s 2Boom’s web site: 2Boom Can’t find any online support you’ll need to ping them directly.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
How to make the buttons on the back work. /radio /up volume down. Skip song's ect.
댓글 달기
I have this speaker - I had to unpair the bluetooth of one machine in order for it to pair with another. Hope this helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
exokiba 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 37
30일 전: 151
전체 시간: 12,179
