주요 콘텐츠로 건너뛰기
Shark Rotator Powered Lift-Away XL Capacity, model NV755. It can convert from a push vacuum to a hand-held vacuum. Repairs and troubleshooting found here may also be applicable to models NV652 and NV752.
23 질문 전체 보기
Dust cup only fills at the top - have cleaned all filters!
I have a Shark Pet Pro-Liftaway, Model NV752. I recently changed all the filters, cleaned everything up, dried the filters thoroughly, and reinstalled. But only the top of the dust cup fills up; not the bottom. With 2 ragdoll cats and lots of wall-to wall carpet, I need to get this fixed. Help!!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 3개
Hello! I recently started having the same problem as you and also after cleaning the filters. Have you found a solution?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I wish I could help you but this is also happening to me and I have a golden retriever. It’s very frustrating.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Same problem. Our new filters in blew air into hoses and nothing appears blocked. Could it be a problem with connections? Such as canister not completely back in place?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Same here. What a bad flaw
댓글 달기
귀하의 답변을 추가하세요
lesliejbrown 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 21
전체 시간: 442
