주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
Error 51 iPhone 7 after restoring
Good day,
A customer of mine had his phone updating however he unplugged the phone accidentally while it was being updated. Now, when i put the phone in dfu mode and restore. Its giving me an error 51. I am aware that this is a board related issue. However, can anyone advise if they experienced this issue so that I can know weather it is the NAND or BBCPU or whichever may be the issue.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Try restoring the phone using 3Utools. Hopefully that works.
If not then I'm sorry to say it's probably the NAND needing to be reprogrammed.
Try getting it restored at an apple store as it could be your computer having issues communicating with the phone properly with iTunes etc.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
it sounds like the IPSW file format is corrupted. the customer might have run a beta or jailbroken version of iOS which can usually be 1 of many reason for error 51
delete the existing saved IPSW in the iTunes directory
for Mac
  1. Launch Finder
  2. Click Go from the menu bar
  3. Scroll down and click ‘Go to Folder’
  4. Type in “~/Library” and click Go
  5. Click and open the iTunes folder
  6. Open the iPhone Software update
  7. Delete the.IPSW files
for Windows
  1. Go to C:\Users\Your Computer Name\AppData\Roaming\iTunes\iPhone Software Update
  2. Find the.IPSW file and delete or you can press CTRL +A (control all) and hit the delete on your keyboard.
  3. Update the iPhone again.
  4. trying an update after this procedure should force iTunes to download a new file format
try downloading a fresh IPSW image currently Apple only sign 11.4.1 and Proceed to update the iPhone
hope this works if that doesn’t work. you might wanna give FoneDog toolkit IOS system recovery a try
cheers
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
MICHAEL JABARI NELSON 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 85
