주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2015년 5월 업데이트에는 5 세대 Intel Core i5 및 i7 프로세서가 성능과 배터리 수명을 약간 향상시켰습니다.
623 질문 전체 보기
No backlight after liquid damage
Should I bother replacing my display assembly on my mac? The logic board works except no backlight on the display. I ordered a used logic board on eBay, but was wondering if I should order a replacement display as well.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Hi Paul,
It completely depends on why there is no backlight. There could be residual corrosion that needs to be addressed. It could be that the backlight on the display itself has failed. With liquid damage, I would suspec that the logic board is the issue. It is certainly repairable by a shop with the correct equipment and knowledge.
Cheers,
Joshua
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
There is no visible damage anywhere on the board. I did a continuity check on the fuse labeled "P" according to some Google results. It appeared fine. I wasn't completely sure how to do a voltage check and didn't want to damage the board further. Also, the pins are so %#*@ small the probes on my multimeter would touch the adjacent pins and give me useless readings.
Also, after I had already seen a non-working backlight, I tinkered around with the LVDS connector cable...accidentally, and, successfully plugged it back in upside down and burnt a solder joint (I think that's what it's called). So I tried messing around with my soldering iron and flux and...probably ruined it more. The Mac still boots up...without backlight. I stopped touching it and ordered a new logic board lol.
I WAS going to try and replace the LVDS cable, but multiple experts have told me that I WILL break the glass. But, I'm not entirely sure yet if the display itself is the problem of the backlight.
댓글 달기
귀하의 답변을 추가하세요
Paul Ko 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 479
