주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
Tried replacing battery now randomly opens apps
I tried replacing my battery on my iPhone 6s Plus. Followed every step as directed and after I got the phone back together it works and the battery charges but after a couple of minutes go by it starts to open apps, dials phone numbers, keyboard appears and starts typing, etc… it’s like it goes haywire. When I turn off the screen then turn it back on it’s fine for a few minutes then starts going haywire again. Tried taking it apart and reconnecting it but still has the same problem. It is difficult to tap icons and to type because it’s not as sensitive to the touch as it use to be. Can’t figure out what the problem is?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Sounds like you have touch disease on the phone. You may want to inspect the LCD/Digitizer cables and make sure you don’t have a damaged pin on there and look at the . Ideally, when you re-seat the cables (ensuring they are properly seated) corrects the issue temporarily.
If you noticed the pin is damaged, then you may need to replace the screen.
You want to also check the board connection for damage as well.
Good luck, let us know what you find.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mike Horiuchi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 105
