주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Home button doesn't working, BUT TOUCH ID WORKS,
My girlfriend’s iphoneSE the home button stopped working( after software update?)
She told me it started after the update. The button clicks normally, but the OS can’t recognise that. The figerprint sensor works(I can add more fingers). I’d like to make sure before I replacing to a normal home button.
Update (08/30/2018)
Alright, I opened the phone, I have a button from an old 5S, working well, but I found something on the original flex cable. Any idea where is this belong?
http://p.coldline.hu/2018/09/01/2908050-...
http://p.coldline.hu/2018/09/01/2908053-...
http://p.coldline.hu/2018/09/01/2908054-...
http://p.coldline.hu/2018/09/01/2908056-...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
It was the part of the Home Button cable.
I suspect the flex-cable as damaged. I will test each lines, it will take a long time. Than I will let you know.
댓글 달기
답변 2개
선택된 답변
It’s in the middle of the flex cable.
Dunno if it has a function but here is an image
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
Although button is just one, touch ID function and click related functions rely on different data lines and components. It might be something went bad along with the update but it’s probably just a coincidence. To not let anything untried before buying a replacement part you might first try resetting the iphone hardware by pressing home and power button together until it restarts..you can try a factory restore too as a second step after backing up your data. If those don’t work try reseating home button connectors..don’t forget to disconnect battery before touching anything else.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I can't recognize that as an iPhone part, I'm sorry.
댓글 달기
귀하의 답변을 추가하세요
Bence 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 85
