Will this battery replacement work for a I Phone 4 Verizon Model?
Phone was dropped in water for 10 seconds. It was dried out and works on the charger, but not the battery. Could the charging circuit be bad along with the battery?
좋은 질문 입니까?
좋은 질문 입니까?
Batteries are cheap. You will get your answer if you change the battery with a known good battery. iP4 battery replacement is very easy, but you must be careful because small fragile connectors are present. Also the bottom case screws are Pentalobe screws. Need Pentalobe screwdriver, or modified flat screwdriver or carefully used edge of square edge razor blade to remove them. Get the New Battery with a Pentalobe screwdriver. Also you will need a Phillips #00 screwdriver to remove the one battery connector screw.
해당 답변은 도움이 되었습니까?
hi brad, was hoping jim would post this as a question to get your help.. I got an email but I'm much more familiar with iphone 3g. Hope this has helped him. cheers, jen
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 605
댓글 1개
hi Jim, thanks for posting your question, brad fixes these for a living so I'm sure he'll be better help than me. Hope you get it fixed. jen
pollytintop 의
